swinging arm gpz1100b2.
andy.s
#1 PostAuthor: andy.s » Mon Jul 09, 2012 7:14 pm
hi guys ,i am trying to get the swinging arm off,it's all unbolted etc but seems tight between the frame, any ideas before the large bar comes out.
thanks
andy :o
will be done soon !!!!!.
GPRD
#2 PostAuthor: GPRD » Mon Jul 09, 2012 8:07 pm
I had to cut the swinging arm out of my GPz750, the inner sleeve had nicely attached itself to the bolt with a fair amount of rust.
What we got here, is failure to comunicate.
#3 PostAuthor: z1bman » Mon Jul 09, 2012 8:23 pm
slacken of the rear engine bolts + it should fall out
andy.s
b2 swinging arm
#4 PostAuthor: andy.s » Mon Jul 09, 2012 9:00 pm
hi guys thanks, after a bit of thought a managed to splay the frame a baw hair with a wooden wedge enough to get the arm out.
cheers
andy :D
big green bus
#5 PostAuthor: big green bus » Fri Jul 13, 2012 7:21 pm
you won't get it back in without loosening the rear engine mount.
andy.s
b2
#6 PostAuthor: andy.s » Fri Jul 13, 2012 8:54 pm
thanks for the tip bgb , its getting a refurb first,so hopefully be in for next weekend.
cheers
andy.
