Gearbox interchanges
Jerry
President
President
#1 PostAuthor: Jerry » Sun Jul 08, 2012 11:49 am
Does anyone know if 1000J gears will fit on the earlier gearbox shafts? I know the gearbox can be changed as a unit, but what about the individual gears?
#2 PostAuthor: zed1015 » Sun Jul 08, 2012 11:59 am
I have just done the GPZ uni cluster in to early cases.
Had to use a 'J' input shaft. Could have used an early input as the gears will swop but the fixed first gear is lower on the early shaft so there would be a larger gap between 1st and 2nd.
Jerry
President
President
#3 PostAuthor: Jerry » Mon Jul 09, 2012 4:27 pm
Thanks for that!
