Sprockets and Things.
greenlaningxt
#1 PostAuthor: greenlaningxt » Thu Jul 05, 2007 9:56 am
I need a bit of help to decide which direction to go.
As far as I can work out my Z1000 should have standard sprockets of 15 and 33. Have seen they can have a 17 front.
I am running a Fireblade back wheel, which alone changes the gearing due to the size change.
Next problem the front sprocket needs to be off set by at least 1/4inch so I am running a 603 pitch GPZ750 51415 sprocket, 15 teeth, (only size I seem to be able to get.)
Rear sproket is a 38 tooth 603 pitch, not sure I will get much smaller due to chain run, maybe a couple of teeth.
I want to be able to have a reasonable speed without too high revs as I plan to do some long distance trips.
Standard sprocket ratio should be 2.2
My current ratio is 2.53 (too high)
Taking into account the change of wheel, what would people suggest as a good mix of sprockets.
As well as a source, any ideas on other front sprockets that might fit given the offset. Standard not expensive billet.
Been told with the pitch of chain the biggest front sprocket I may get away with is a 16.
Harris Z1000, Several other Road, Off Road and Trials Bikes, Delica Exceed
http://www.greenlaning.co.nr
#2 PostAuthor: chrisNI » Thu Jul 05, 2007 4:01 pm
Try calling Talon they have a lot of different sprockets off the shelf and they are not horrendously expensive for a one-off. Tell them we sent you.
#3 PostAuthor: Rich » Thu Jul 05, 2007 5:59 pm
Better to keep the front for 630 chain at 15. Is it for your Harris? mines running 15 / 31 : 70mph at 4250 revs : 80 at 5K with a race fairing. It's depends what the circumferance of the rear tyre is for the final gearing I run 160/60 * 17 rear.
Watch the chain catching the top of the swinger pivot you need a rubbing strip for it to ride on preferably.
#4 PostAuthor: Pigford » Thu Jul 05, 2007 6:15 pm
I RUN A 180/55 x 17 REAR, WITH A BILLET OFF-SET FRONT SPROCKET AND 630 CHAIN.
THE OUTER CHAIN CASE COVER NEEDED A SMALL BIT OF FILING ON THE REAR EDGE WHERE THE CHAIN RUNS TO AVOID RUBBING. THE INNER GUARD PLATE CANNOT BE FITTED :wink:
I've always been told not to reduce front sprocket too much, if at all, as the tighter turning is a major wear factor for the chain and it also saps power :!:
greenlaningxt
16 Teeth
#5 PostAuthor: greenlaningxt » Sun Jul 08, 2007 4:33 pm
Now have a billet 16 tooth front sprocket, thanks to super quick delivery from Debben Performance, although at a price.
Worked out I had to go for a 16 front as I do not have enough room on the back to go down as far as 31 teeth.
If I can get down to a 35 on the back I should be in the right ball park. Should give me a ratio of 2.18 were as the standard is 2.2 I was on 2.53
Had to remove some of the cover as the chain does rub, as per comments above.
Will now be getting a rear sprocket made up, although not 100% sure what size yet. 35, 36
Might try for a similar ratio as Rich has, although would like to know what size sprokets you are running Pigford as I have a 180 on the back as well.
Thanks for the help!!!
#6 PostAuthor: Pigford » Fri Jul 13, 2007 3:29 pm
I got a 36t on the rear, but dunno what front off-set sprocket is :?:
Can't be arsed to take cover off, unless you really need to know :? :D
greenlaningxt
Sprokets
#7 PostAuthor: greenlaningxt » Fri Jul 13, 2007 4:12 pm
No problem, have a 35 tooth rear sproket on the way.
Should sort the gearing out just right.
Users browsing this forum: Bing [Bot] and 16 guests
