I also had a disc mount made up to hold the ZX6R rear brake setup but dont have pics of it, its now powdercoated white & fitted to the rim
The tail unit build
florists foam used to get a general shape
Covered in Aluminium foil so the glass resin didnt melt the foam
Filled, primed, sanded, Filled, primed, sanded, Filled, primed, sanded, Filled, primed, sanded, Filled, primed, sanded, Filled, primed, sanded
Ready to paint
Now the seat
Wooden mid section so the trim could be stapled to it, shaped to fit a 'bent to fit' piece of aluminium that matched the lines of the seat base, this was used so i could fit rivet nuts to attact the seat to the base
Trimmed with seat foam
