Camshaft fitting
carpy
Camshaft fitting
#1 PostAuthor: carpy » Sun Jun 24, 2012 10:48 pm
When refitting the camshafts how do you ensure the camchain remains engaged on the crank, did mine today and it wasn't, just seems a bit hit and miss. Any good tips from anyone whose done this loads of times as it seems dead fiddly
#2 PostAuthor: kev edwards » Mon Jun 25, 2012 9:18 am
When working on my own i always put a small cable tie around the chain and loop a reasonably strong elastic band through it and cable tie the band to the frame thus keeping some tension on the chain, if someone else is around i just get them to hold the chain up.
#3 PostAuthor: ADRIAN H » Mon Jun 25, 2012 11:20 am
kev edwards wrote:When working on my own i always put a small cable tie around the chain and loop a reasonably strong elastic band through it and cable tie the band to the frame thus keeping some tension on the chain, if someone else is around i just get them to hold the chain up.
+1 gets my vote - Cable tie and elastic band to frame.
CAT3
#4 PostAuthor: CAT3 » Mon Jun 25, 2012 12:43 pm
With the cam-chain tensioner retracted, I just sit both camshafts in place, (doesent matter about cam timing at this point) to hold the chain up.
However, I like the elastic-band method :D
#5 PostAuthor: Pigford » Mon Jun 25, 2012 4:39 pm
The chain can sometimes come away from the crank - but as its not that often you have to re-fit it, I just spend a while messing about until it er-locates on the crank sprox :wink:
