But after rebuild she been running a bit rich[very dark brown] but did not bother me as she rides so well.But ive noticed she pops abit when you are of the throttle and the plugs are getting a bit sooty.Apart from that runs like a dream but like to sort it.
This is what i have checked.Carbs are z1000 26mm
Not sure if jets are correct.got a gunson but cant see much change when adjusting.The adjustment is a mixture screw not air but is the same difference yes:?:
got 11volts at the coil.would 1volt drop make the difference
