My "new" Escort Rs...
davy thomson
- ZedHead
Jumbo wrote:Best get the pictures posted and show us what you have.
I have a Mk 2 Talbot Lotus Sunbeam "resting" in the garage. Hopefully get it back on the road one day. Along with the Kawasaki KH250's x 2 also "resting" in the garage !!
A talbot Sunbeam Lotus was an Escort RS 2000's biggest nightmare!!!!
Jimmock.
I hate people I don't like !
I spotted this car a bit a go and knew it was the one for me.I couldn't get to see it as i was going on holiday and it seemed as though it wasn't meant to be as when i returned it had changed hands.
It then reappeared and i just had to have it.Its absolutely and totally what i was looking for.Its a reasonably tidy and solid clubman rally car.Its been done to a decent standard in the past and reckon its had a fair few quid spent on it.Some might groan at it only having a crossflow fitted,but for me its just perfect.I really couldn't be happier..
This is a brief spec..
Alloy arched 5 linked shell , strengthened , gussetted , strut brace . full SD cage inc Diagonal and door bars. Seat mounting bars , lightweight bonnet , boot and doors with poly carb windows. GP.4 alloy front spoiler .
Engine
Fitted with a rally spec. 1600cc Ford X/Flow engine (Kent), running on Twin 40 Webers , itg filter and twin throttle linkage , steel rocker gear , alloy rocker cover , rally cam etc Lucas comp dizzy with Lumenition. (Previous owner said gives 120bhp @ wheels) 4 into 1 exh manifold and L/Hand exhaust system. Oil cooler etc.
Transmission
Rocket 4 speed Tran-X s/c c/r gear box , quick shift gear lever , single propshaft , strengthened & braced English axle with LSD
Suspension/Brakes
Bilstein World cup front struts with RTM , WCXM , Q/rack , Uprated anti roll bar with double width mountings, Alloy sump guard , Bilstein rear turret dampers , single leaf slipper springs and 5 linked axle (has option on shell to fit watts linkage set up) Adj. bias pedal box , hyd hand brake , aeroquip flexi , RS2000 vented brakes etc .
Other parts
Shaped Alloy fuel tank , twin facet fuel pumps , filter king , boot mounted battery , BDA Big header radiator , alloy catch tank , Be spoke dash with various gauges and uprated tacho , Rallymaster trip meter , Suede dished s/wheel . Lightweight seats/belts . Minilite wheels , Plumbed in zero 2000 exting & H/held.
Engine
Transmission
Suspension/Brakes
Other parts
Users browsing this forum: No registered users and 1 guest
