Big bore kits for a Z1100A1 ???
Big Fluff
#1 PostAuthor: Big Fluff » Fri Jun 15, 2012 6:17 pm
I know the Z1100A1 (shaft drive) engine is based on the 998cc Z1000J, but what size will the standard liners go out to :roll:
I'm sure the crankshaft has 18mm wrist pin size, and am looking at a 1135cc MTC piston kit but don't want to have to resleeve and bore the top crankcase out.
Thanks, Will
#2 PostAuthor: ADRIAN H » Fri Jun 15, 2012 7:58 pm
Cylinder bore only.
link to mtc pdf , says they come as 17mm wrist pins, but can be honed to 18mm ?
http://www.mtceng.com/images/pdf_files/ ... piston.pdf
#3 PostAuthor: ADRIAN H » Fri Jun 15, 2012 8:09 pm
Just remembered another link for piston kits. Only seem to list the 1170 kit.
APE. kz zone.
http://kzzone.com/pistons.html
nanno
#4 PostAuthor: nanno » Fri Jun 15, 2012 8:10 pm
Whether you have 17 or 18mm pistons, depends on the model year. There are Z1100STs that have a classic J bottom end and some that already have the later UT crank (83 onwards IIRC)
Greg
Big Fluff
#5 PostAuthor: Big Fluff » Fri Jun 15, 2012 8:21 pm
Thanks guys, appreciated.
