Master Cylinder Sight Glass
stempy
#1 PostAuthor: stempy » Sat May 26, 2012 7:02 am
I need to replace the sight level glass in my clutch master cylinder, does any body know off any companies that sell replacements or replaces the window for you
Rick
GEZ635
#2 PostAuthor: GEZ635 » Sun May 27, 2012 9:57 am
They are stil available from kawasaki or z-power. They simply knock out. The new one will push in but put a bit of sealant around it first (Three bond).
Gez
stempy
#3 PostAuthor: stempy » Sun May 27, 2012 8:05 pm
Gez
had a look at z power but could not find one,do you know of the part number and what three bond sealent would you use
Rick
paulstrees
#4 PostAuthor: paulstrees » Mon May 28, 2012 6:43 am
I think Gez is thinking of the clutch cover sight glass?
Crofty
#5 PostAuthor: Crofty » Mon May 28, 2012 8:38 am
Would help to know what master cylinder we are talking about. Kawasaki alone had different sized ones for various brake master cylinders,
and is it clutch or brake m/c as no Z1 had a clutch master cylinder as standard. Picture?
stempy
#6 PostAuthor: stempy » Mon May 28, 2012 7:41 pm
FZR 1000 cluctch master cylinder but is a 5/8 nissin
Crofty
#7 PostAuthor: Crofty » Tue May 29, 2012 7:24 am
I have just measured the one of the type I used to fit into my rectangular brake m/c on the 650 and it is 25.10mm. Actually not available as a spare part for the m/c, but is the oil sight glass in the clutch cover.
Yours is much smaller, sorry I can't help. Crofty
Is Vic There
#8 PostAuthor: Is Vic There » Tue May 29, 2012 9:04 am
I sent my brake and clutch master cylinders off to a bloke in the US who refurbished them including putting new sight glasses in them, first class job. They were off the GPZ900 but that should not matter. I'll dig out the info if you like?
stempy
#9 PostAuthor: stempy » Tue May 29, 2012 6:33 pm
Was this the guy who did it for you
http://www.ebay.co.uk/itm/220935593849? ... 1438.l2649
or has anyone tried these
http://www.ebay.co.uk/itm/87-v-max-vmax ... 53e13f5a0b
Rick
Is Vic There
#10 PostAuthor: Is Vic There » Tue May 29, 2012 8:43 pm
Hi Rick,
Yes Bob thats him!
I sent over a seal kit and they came back like new.
Hope these pictures help
