z1b handle bar options
bob fell
#1 PostAuthor: bob fell » Tue May 22, 2012 7:18 pm
Hi guy`s
I have a Z1B which is not standard but is slowly evolving into a nice looking bike, slightly street fighter look....marsahall 4-1 exhaust, it has no rear mudguard which looks good, alloy rim stainless spoke wheels and recently I have put a cut down seat on it and I`m happy with the changes I am planning on putting a short mudguard on the front which are available from Z power my question is about handle bars..... I have seen some cool bikes on the projects forum and some seem to have flatter bars like drag bars,are these available and can they go straight on a Z1B... are there any issues with cable lengths etc
any advice appreciated
Bob
carpy
#2 PostAuthor: carpy » Tue May 22, 2012 10:07 pm
I've got Renthals on mine and needed shorter cables
Z903
#3 PostAuthor: Z903 » Wed May 23, 2012 8:19 am
I put drag bars ( from Z1 Ent.) on my Z1-A, but to get the brake master cylinder to clear the fork tops and get a reasonable ergonomic angle, I had to fit 15mm bar risers. Though I have seen other bikes that haven't needed to do this? but it's something to be aware of.
steve bowdler
#4 PostAuthor: steve bowdler » Wed May 23, 2012 9:19 am
Z903 wrote:I put drag bars ( from Z1 Ent.) on my Z1-A, but to get the brake master cylinder to clear the fork tops and get a reasonable ergonomic angle, I had to fit 15mm bar risers. Though I have seen other bikes that haven't needed to do this? but it's something to be aware of.
So what clutch and throttle cables did you use ?
scott
Junior Section leader
#5 PostAuthor: scott » Wed May 23, 2012 10:23 am
I've got straight drag bars on mine......had to make some nice risers.....all cables are for a z650....a fair bit shorter than z1000 cables.
jimmock
#6 PostAuthor: jimmock » Wed May 23, 2012 10:55 am
Get a set of 1970 MK1 Raleigh Chopper bars on it!!!!
The MK1's were adjustable!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
bob fell
#7 PostAuthor: bob fell » Wed May 23, 2012 11:15 am
thanks for the replies
Can you buy risers or do you have to make them? is there a kit.. like bars and risers available for a Z1B ? It`s starting to sound a bit complicated
steve bowdler
#8 PostAuthor: steve bowdler » Wed May 23, 2012 11:26 am
Thanks Scott :D
Z903
#9 PostAuthor: Z903 » Thu May 24, 2012 8:37 am
I've used the MX ones that are readily available...but look crap on an old bike? I need to find an old school set that just uses longer bolts rather than the offset bolts that this type use. (too wide)
Because I have a bikini fairing I've managed to soldier on with the standard cables but the 650 items sound like the way to go.
scott
#10 PostAuthor: scott » Thu May 24, 2012 10:36 am
Bob fell......anyone who knows how to use a lathe or mill could knock up a set of risers for you in a few hours.....i just gave the original clamps to a machinist and stated that i "wanted a pair of these made but out of alloy/stainless steel instead and lengthened by about 3 inches"
scott
#11 PostAuthor: scott » Thu May 24, 2012 10:39 am
Big John
#12 PostAuthor: Big John » Thu May 24, 2012 6:51 pm
Pretty sure you can get long or short cables for Zeds, doesn't taller risers rather defeat the object of having flatter bars ?
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
000zeds
#13 PostAuthor: 000zeds » Thu May 24, 2012 7:45 pm
Long and short cables are available for Z1s
Zeds-R-Us
bob fell
#14 PostAuthor: bob fell » Thu May 24, 2012 8:05 pm
Thanks again, cool pix too, I can actually get blocks of alloy (off cuts) from work ;) I guess a way to go would be to measure the distance of the position of the brake and clutch lever from the floor and then figure out how big the riser would have to be. Can I use any bars as long as they are the correct diameter? The flat bars really enhance the look of the street fighter type style
scott
#15 PostAuthor: scott » Fri May 25, 2012 7:05 am
Big John......i'd rather ride at 100mph with slightly raised flat bars than standard cowhorns.......feels less windy.....and feels like you have more control/weight over the front end.......not as good in very slow traffic to cowhorns though
