Hi I am looking to buy a twist grip for my Z1B as mine has a fast action throttle fitted. Not sure if the Z900 Z1000 one is the same if some one could let me know.
Wanted a twistgrip throttle tube for a z1b z900
ADRIAN H wrote:z900 onwards https://www.z-power.co.uk/merchantmanag ... cts_id=153
this would probably do the job if you changed the rubber grip to the z1a type but not sure the holes for the cable nipples are the same distance apart + you might have problems fitting the cables. but i am sure someone at z power would know
