Bolt plating
DavidZ1R
Bolt plating
#1 PostAuthor: DavidZ1R » Tue May 08, 2012 6:52 am
Just a quick question, when old bolts are re plated are they done in bright zinc or nickel?
#2 PostAuthor: Ginger Bear » Tue May 08, 2012 7:58 am
I would say normally bright zinc, but Mikey will do 'em with a yellow passivate or olive drab, pretty much anything you want.
# 104
Zed man
Re: Bolt plating
#3 PostAuthor: Zed man » Tue May 08, 2012 8:54 am
DavidZ1R wrote:Just a quick question, when old bolts are re plated are they done in bright zinc or nickel?
I use a small zinking kit, and i put them (rusty bolts/pieces) in patieo cleaner, then rinse, copper wire, into the zinking kit, for 15/20 mins, comes out, gray, rince off, wipe off, then polish on a small 8" grinder wheel, with a polishing mops. Then into the orange passivate! job done.
Polishes up like chrome. I use this for only small parts. but a saving is a saving, and not wait for a few weeks, to get it back. I can take it off, the bike, in the morning, and put it back on the bike before lunch!!!
Once it's been zinked
then polished
And some air box parts, not kawersaki.
Air box before restoration.
And the completed Restored air box. Good for another 40 years. Job Done!
Garn 1
#4 PostAuthor: Garn 1 » Tue May 08, 2012 11:15 pm
There are a few bolts that need re-plating that were originally chrome. The items I'm referring to are those little 6mm bolts that have the number "7" embossed on them.
Does anyone know how these are handled, regarding re-chrome plating?
My thoughts are..
De chrome.
Fine bead blast.
Copper, nickel then re-chrome.
lightly polish.
Another query is, the early Z1 head nuts are not usually heavily (brightly) chrome plated, they usually still have the machine marks still present and have a nickel plated look!
Anyone care to comment on this renovation process?
jimmock
#5 PostAuthor: jimmock » Wed May 09, 2012 1:06 am
STAINLESS, STAINLESS, STAINLESS, STAINLESS.
IT IS THE ONLY WAY FORWARD.
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
KeithZ1R
#6 PostAuthor: KeithZ1R » Wed May 09, 2012 7:18 am
jimmock wrote:STAINLESS, STAINLESS, STAINLESS, STAINLESS.
Jimmock.
tis till you can't get the fekers out cos they've binded
up, :(
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Mark Stratton
#7 PostAuthor: Mark Stratton » Wed May 09, 2012 12:33 pm
Always use copperslip or similar between stainless and aluminium as the aluminium will react when it comes into contact with stainless and corrode them together.
