Lost key
Robw
Lost key
#1 PostAuthor: Robw » Sun May 06, 2012 10:25 am
Hi, it looks like I have lost the key to my GPZ900 does anybody know of someone who would be able to make a replacemnet key from the ignition barrel.
Cheers Rob
#2 PostAuthor: Rich » Sun May 06, 2012 4:44 pm
the lock usually has a three digit number on it which is the key code. You should be able to get a key using it e.g.
http://www.key-men.com/shopping/show_ca ... d=Kawasaki
or your local Kwak shop
#3 PostAuthor: z1bman » Sun May 06, 2012 4:58 pm
if you can remove the ignition switch the key number is stamped on the flat side of the front of the switch in small numbers key number will start with a z followed by 4 numbers example Z5674.
this company has all the major key codes just give them your key no if you can find it
Ashfield Security
160a High Street
Blackheath
West Midlands
B65 0DX
TEL: 0121 561 3332
Robw
#4 PostAuthor: Robw » Mon May 07, 2012 11:26 am
I have taken the ignition switch of the bike and have taken the switch out off the ignition housing. Are the numbers on the actual tumbler? The 3 roll pins have been drilled out but it is still reluctant to come out.
Cheers Rob
#5 PostAuthor: z1bman » Mon May 07, 2012 12:18 pm
the numbers are on the aluminium casing part of the switch but are really small you would be advised to use a magnifying glass to read them there are no numbers on the tumblers. have a look at the metal plate by the steering lock on the switch. if your key is the same as the seat lock remove the l/h side panel + remove the lock the key no is also stamped on the lock
Robw
#6 PostAuthor: Robw » Mon May 07, 2012 1:09 pm
Found the numbers, had to give the switch a good clean, the number is z 5@@@
does this sound right. There is another set of numbers below the steering lock. Today was such a bore all that time on set with Ellie and my crew. I am expecting the offers to come flooding in. Golden globe next!Many thanks for your help I owe you a beer,
Regards Rob
tlc
International Rep
#7 PostAuthor: tlc » Mon May 07, 2012 3:45 pm
Yes the Z#### is correct.
Asphalt Cowboy
Robw
#8 PostAuthor: Robw » Wed May 09, 2012 7:32 pm
Spoke to Ashfield security yesterday morning, key arrived today. Fantastic service and recommended.
Rob
#9 PostAuthor: z1bman » Wed May 09, 2012 7:34 pm
good result :) :) :)
