Z1000 Carbs
Tawkin
Z1000 Carbs
#1 PostAuthor: Tawkin » Sat Apr 28, 2012 5:23 pm
Hi all,
I'm after some carbs for a Z1000 A1/2. No's 2 & 3 are apparently no good (have a garage getting the bike road-worthy for me).
Anybody able to help?
Just missed a set on ebay for £64 which I don't think is a regular occurrence!
ukcoupe
#2 PostAuthor: ukcoupe » Sat Apr 28, 2012 7:50 pm
would these be any good?
http://www.ebay.co.uk/itm/330722762235? ... 500wt_1359
cheers
Chris
DDZ900
zed carbs
#3 PostAuthor: DDZ900 » Sat Apr 28, 2012 8:37 pm
iv plenty of z900/z1000 carb bits if you need anything :wink:
Holeshot
#4 PostAuthor: Holeshot » Sun Apr 29, 2012 9:09 am
Hi Chris,
I've a set of mint ones taken off my A2 .
They've come back from a total rebuild by Oz at Zed Parts.
It was a no expense spared job, so unltrasonically cleaned, new seals, gaskets etc with choke & float heights set etc etc.
Oz is meticulous so they should be as near to new as you can get for a 30+yr old item.
They ran well on my bike before but I wanted them 100% but whilst they were being done I bought a set of smoothbores which I've since fitted so these are now surplus to requirement.
The only thing missing is the main jets as I changed those due to the engine being tuned.
All settings are standard - you'll just need to fit the main jets of your choice.
They may be out of your price range as I'm looking for £250 but let me know if you're interested anyway. I can send pics if you want.
All the best sorting your bike out in any case.
Hilton
Tawkin
#5 PostAuthor: Tawkin » Sun Apr 29, 2012 1:47 pm
Thanks for the responses.
Will see how the ebay ones get on (cheers Chris, don't know how I missed those) and report back.
Hilton, yours look very tempting but I'd rather not stretch that far just yet!
Trevor
Holeshot
#6 PostAuthor: Holeshot » Sun Apr 29, 2012 4:55 pm
Hi Trevor.
Sorry 'bout getting your name wrong :oops: (apologies to Chris too)
No worries - they're a bit pricey due to all the work.
Good luck with the other options & hope you get your Thou out for the dry weather.....whenever that may be!!!
Hilton
RGH
#7 PostAuthor: RGH » Tue May 01, 2012 11:40 am
If you want the best.
About 4 years ago I nearly bought set A1 carbies (could be the same set???) off this seller for $400.00USD. hhhhhm.
http://www.ebay.co.uk/itm/Kawasaki-KZ10 ... 3908976553
