Fuel problems
- paul doran
Fuel problems
My Lawson 1100 wont start
its had a new head gasket fitted
shims done and carbs ultrasonically cleaned
I have also overhauled the fuel tap
the engine spins over freely there is fuel in the carbs but plugs are dry after trying to start it
if I put fuel down the plug holes it will fire
any ideas please
any ideas please
- paul doran
If the inlet cam timing is a little off you can get down to near zero vacuum on the starter.
No problem for slide carbs but CV's.................
If you have some vacuum gauges give them a try and the vac reading is around 22 ish.
If its less or no reading at all and they're morgan sliding tube gauges then turn the gauges upside down!
Wrong is 41 and 67 degrees where you should have 35 and 65 degrees thats approx equivalent to 103 lobe centres. Torque to spare but it wont start!
- Chunks
- paul doran
- paul doran
Sounds like the pilot circuit on each carbs is blocked, but that would be very unusual, everything engine wise sounds ok, especially if valve timing checks out. Seems there is just no drawing the fuel up from the float chambers, I would have the carbs off again, I'm not familiar with the 1100 set up, are they CV carbs and vacuum tap?
have you tried it in the prime position? if you have fuel in the float bowls it is possible a pilot jet is blocked. chances of all four being blocked at the same time very remote? are the inlet rubbers in good condition no leaks at the mounting surface. if you remove the carbs + hold the palm of your hand over the inlet rubbers have you got good suction
