What is a good way to clean an engine without stripping it, I am looking at stripping the A4 getting the frame coated and doing a general tidy up, not a resto so not going overboard.
Soda / aqua blasting ?? what works?? Thanks in advance....
Andy M wrote:This is the engine.. it may not need blasting, ??/
Z.O.A wrote:Soda does a great job, but as said before, it does not remove any of the oxidisation or corrosion, it can't do this because it's not an abrasive, I believe it .....bead and doing the entire engine, did a fantastic job and left a nice smooth finish.
hillbilly wrote:fourth pic back,you might want to swap the inlet rubbers round.
