Z650 into 810 project
Royalratch
#91 PostAuthor: Royalratch » Mon Apr 09, 2012 8:21 pm
I was speaking to a chap that's making some bits for me and he said he's seen them mounted there, pretty small ones, behind the battery box. The rear wheel can act as a 'fan' and give some good direct air flow if placed just right. Longer oil lines also mean extra cooling and more oil capacity.
#92 PostAuthor: Rich » Tue Apr 10, 2012 6:27 pm
Mounting oil coolers in seat units is not new. If you louvre the top of the seat unit for an output and duct air through to the cooler it will probably work better than being placed at the front of the engine. An alternative would be to duct output air around the rear light into the low pressure zone. You will need to look at battery sighting if it is going to be there and creating a high pressure zone in front of the cooler, preferably turbulent air, your body / rest of the bike will create a low pressure zone after it.
Crofty
#93 PostAuthor: Crofty » Wed Apr 18, 2012 8:47 am
Some activity yesterday, got my barrels back fron SEP and new rings. Fitted the top end and have got as far as fitting degree disc to crank, before I got too tired. I needed some of those rubber grommets that go in the bottom of the barrels that stop water lying on the crankcase top and prevent corrosion. I was at the local bike seat recoverer Smart RRRs and he made me some using a sheet of thick rubber and some of his leather punches.
Homebrew barrel rubbers.
Rings bound up in drainpipe and cable ties.
Finally together.
GUYZED
#94 PostAuthor: GUYZED » Thu Apr 19, 2012 4:38 am
Coming along nicely there Jim...keep us updated on its progress.
I like the homebrew barrel rubbers...good idea :up
#449
Z1000A2 Z650B1
j.wilson
#95 PostAuthor: j.wilson » Thu Apr 19, 2012 8:00 am
Watch out fitting the cooler in the normal place infront of the engine- only little ones will go in if you have standard wheels- the front wheel is nearer the frame on the z650 because of the headstock design.
A cooler will go in- just not a fancy double row aftermarket jobbie.
I put in one I had on my 1100R and found that under full suspension compression the front mudguard hit it.
z650/1400 bonneville hybrid.
Crofty
#96 PostAuthor: Crofty » Thu Apr 19, 2012 8:23 am
True, I was aware of this, the one I used was a small Kawasaki GT750 shaft one with std lines. The front wheel is 18", now and not 19", I slid the forks up through the yokes to recreate where the wheel would compress to, so I could check clearance. They also need mounting high so that the warmed air passes over top of cambox, which I read somewhere (to stop exhaust cam getting too hot), not sure it would be that much of a problem though.
j.wilson
#97 PostAuthor: j.wilson » Thu Apr 19, 2012 8:31 am
Excellent, I figured that you would were smart enough to have checked it but then I thought it would be rude not to warn you given that it caught me out.
Crofty
#98 PostAuthor: Crofty » Thu Apr 19, 2012 8:47 pm
Me, smart! Just taken all day to degree my cams in, but sorted now
105 inlet, 107 exhaust, as Phil at Joy Engineering said.
And if I was smart I would of remembered to order a cam cover gasket after using my spare when servicing my other 650, now waiting for postman.
Baldylocks
#99 PostAuthor: Baldylocks » Sat Apr 21, 2012 10:33 am
Nice one Crofty, coming along really well :clap
Bugger ! whose Idea was that!
'78 Z1r '79 z650/1100 '77 Seeley H**** 750 GPz1100 B2 '86 GSXR750R Ltd '97 KTM620 '76 S3a 400
GPRD
#100 PostAuthor: GPRD » Sat Apr 21, 2012 2:17 pm
Crofty wrote:Me, smart! Just taken all day to degree my cams in, but sorted now
I've got a spare if you want to get on with it.
What we got here, is failure to comunicate.
Crofty
#101 PostAuthor: Crofty » Sat Apr 21, 2012 8:44 pm
Cheers Gary, but the gasket landed this AM thanks to Z Powers quick service.
GB is sending me 4 shims to finish top end, then engine can be wrapped up and put aside, while I crack on with chassis recoating etc.
Crofty
#102 PostAuthor: Crofty » Tue May 01, 2012 7:54 pm
Guy, if you make rubbers that way, after they are stamped out they narrow at the waist, but if you make it from rubber twice as thick, you simply cut through the waist and hey presto, two rubbers for one pressed out bit. Had to experiment with different punches as the rubber distorts a lot and does not end up same size.
Crofty
#103 PostAuthor: Crofty » Wed May 02, 2012 11:41 am
Frame, wheels and tinware all with powdercoater, picked up my oil cooler lines from allenchrome and a used warning light console came in the post.
I think I will end up spraying the oil cooler line ends vht matt black, the bright finish won't look right.
Bill Newman
#104 PostAuthor: Bill Newman » Wed May 02, 2012 7:09 pm
Nice work there Jim.
I very much like the concepts.
Bill
Baldylocks
#105 PostAuthor: Baldylocks » Sat May 05, 2012 9:08 pm
Crofty, don't bother painting them black..it'll just peel off! :D plus they are so low down and will be hidden behind the exhaust I wouldn't worry about it...
