z900 z650 ,z1000 front mount brake caliper body
- ade woollams
z900 z650 ,z1000 front mount brake caliper body wanted threads and nipple ok.its for my kh think all the bodies are the same .
Steve Cooke
There are differences such as the bleed nipple position, Z900 nipple is central Z1000 is to the side, I have one (body only) which I think is A1 with the nipple to the left when looking at it which I think is in good condition but I'd have to check, if that's any good you can have it for the postage. I think they'd all work just depends how fussy you want to be.
- ade woollams
thanks steve.if your bleed nipple is either right or left it will be an a2 behind the forks .i need front mount ,bleed nipples then are all in the centre .thanks for the offer.
Steve Cooke
Hi Ade
Try DK bikes in Newcastle (Staffs) or this ebay seller for your caliper mate.
http://myworld.ebay.co.uk/jdcs42/?_trksid=p4340.l2559
Cheers from Mark
Cheers from Mark
caliper body
Ade. found this one the threads are ok but the body has a bit of road rash
Will it do ? Andy C.
