GB's 'Period' modded Z1000A2 with 'Toast Racks'
Padders
#16 PostAuthor: Padders » Sat Apr 07, 2012 6:17 pm
You will have fun adjusting the tickover on the middle two Steve :D
keep at it she will start.
#17 PostAuthor: Ginger Bear » Sat Apr 07, 2012 7:28 pm
Ironic thing is there's no air screws, they're blanked off, just a fuel screw underneath, but I will swap 'em round in 'due course' :roll:
# 104
Crofty
#18 PostAuthor: Crofty » Sat Apr 07, 2012 7:52 pm
Good job GB, if your fuel leak don't go away, try plumbers ptfe tape around the end of the t piece. I picked that tip off the KZ650 site and as precaution did all 6 joints on me 650 carbs, 2 years on and still no leaks. Crofty
#19 PostAuthor: Pigford » Sat Apr 07, 2012 9:22 pm
Ginger Bear wrote:Ironic thing is there's no air screws, they're blanked off, just a fuel screw underneath, but I will swap 'em round in 'due course' :roll:
Usually carbs only have one or t'other - not both :wink:
#20 PostAuthor: Ginger Bear » Sun Apr 08, 2012 10:52 am
Ok, wheeled the thing towards the door this morning & after a couple of kicks it fired up. :lol:
Pipes are quieter than I expected, but did deposit another load of shit all over my drive.
I ran the bike for about 5 minutes & whilst it appeared a little smokey from 3&4 that seems to be because the choke plunger on No.3 wasn't seating properly, things cleared up once that was pushed fully home.
I thought I'd check the regulator whilst it was running;
Another part for the bin. :roll:
There was some oil pressure;
Overall the bike sounded pretty good, there were certainly no nasty noises. :D
Click the pic for the bike running for the first time in 17 years. :shock:
This link should also take you to the original ebay ad;
http://www.ebay.co.uk/itm/270810560265? ... 1423.l2649
# 104
coldsummer
#21 PostAuthor: coldsummer » Sun Apr 08, 2012 11:05 am
Well done Steve, always nice to hear it run for the first time. Looking forward to seeing this one progress.
Padders
#22 PostAuthor: Padders » Sun Apr 08, 2012 11:06 am
Looks like you got your self a bargin Steve.
#23 PostAuthor: Ginger Bear » Sun Apr 08, 2012 11:23 am
She's hiding a couple of dark secrets Ian, :roll:
RH switchgear is completely disconnected, so the other day I shorted across the solenoid terminals to see if the engine would spin over.........
....................... well the starter motor spun, but that was it.
I then came across this in a box of spares that came with the bike;
I whipped of the alternator cover & found the starter clutch to be locked solid, which was obviously the reason the idler gear had been removed.
I delved a little deeper & removed the rotor, which just about fell off, it is badly scored & the end of the crank ain't looking too pretty either.
The only way I could get the large starter gear to spin was to remove both thrust washers & the damper. :shock: Certainly not a 'long term' solution. :roll:
Looks like it'll need a new rotor at least. :roll:
The other side of the engine hasn't escaped the 'butchery' either, look at the state of the nut on the end of the crank. :shock: :shock: :shock:
# 104
Padders
#24 PostAuthor: Padders » Sun Apr 08, 2012 12:38 pm
Some people should not be allowed near bikes with a tool box.
I am sure you will get her sorted Steve.
Andy M
#25 PostAuthor: Andy M » Sun Apr 08, 2012 2:28 pm
Can't expect the earth for that money, bound to be some secrets when you delve in deeper, we forget the age of these things and the past life they may have lead. Looks good for the money. :wink:
#26 PostAuthor: Pigford » Sun Apr 08, 2012 3:34 pm
Grand job Bear :P
mikey
#27 PostAuthor: mikey » Sun Apr 08, 2012 4:40 pm
Keep at it steve itll come good in the end
let us know how you sort the stater clutch problem as i got same on mine
but when i rang Zpower to order the thinner damper they said
NLA but still insisted its safe to run without the thrush washer and the damper in place.
Done about a 100 miles on mine this week took the altenator cover off
this morning to have a check and all seems ok in there.
Sorry if this sounds like a thread hi jack.
#28 PostAuthor: Ginger Bear » Sun Apr 08, 2012 5:03 pm
Not a Hi-Jack Mikey, it's useful info. :up
# 104
Steve Cooke
#29 PostAuthor: Steve Cooke » Mon Apr 09, 2012 11:22 am
Steve your carbs look like A1 rather than A2 with corrector jets fitted? and Z1parr I don.t think your carbs are A1 carbs although they're all usable. I'm going off the top of my head here so may be mistaken.
#30 PostAuthor: Ginger Bear » Mon Apr 09, 2012 11:34 am
Deffo air corrector jets in there Steven & deffo 26mm, but after all these years it's tricky finding out what was original.
# 104
