Yellowing of chrome
Yellowing of chrome
As per title the chrome on the headers on my Z1B have yellowed slightly
mostly on no1 cylinder. Is it possible to polish this off without affecting the finish {dont want to be left with scratch marks in the chrome}.
Alan, that yellowing is usually the first stage of "bluing" of the pipes and usually caused from excessive heat of that cylinder pipe, which is attributed from mal-tuning. If you have checked that all cylinders are "in tune" then I would look at a topic somewhere in this forum that deals with a special polish that does remove bluing. If it is not too advance it can be done.
I always think a slight discolouring is ok, however, all pipes should look the same!
Regardz.
Regardz.
Alan , further to my previous post, here is something recent on one of the products I was talking about. There are many more posts on "Blueing" on our own forum... Just hard to find! Perhaps a moderator could help.
<http://www.kzrider.com/forum/2-engine>
I always practised this theory......
A cylinder burning oil will run a LOT hotter and thus cause the blueing effect.
Anything that can cause over heat in exhaust gasses will blue the headers.
Jimmock.
Jimmock.
Jimmock.
I hate people I don't like !
Alan, have a wade thru these...
Search found 10 matches
Z1OwnersClub GB Forum Index
Forum Topics Author Replies Views Last Post
Bike Help 4 x 4 Doremi exhaust.
[ Goto page: 1, 2 ] DaveZ1A 20 446 Sun Mar 25, 2012 4:50 pm
john_roscoe
Bike Help 1973 Z1
irhobotolo 12 462 Tue Mar 02, 2010 8:23 am
Andy T
Bike Help Pipe colour
[ Goto page: 1, 2 ] mikey 22 740 Mon Jan 25, 2010 2:47 pm
02GF74
Bike Help 81 Z650 F2, carbs, fuelling, jets and pipes
[ Goto page: 1, 2 ] m1ks 16 310 Sat May 16, 2009 8:00 am
mick z1a
Bike Help Bluing of Pipes
Garn 1 8 243 Mon Apr 27, 2009 7:31 pm
paulstrees
Bike Help First ride problems
Z1B Alan 12 252 Wed Apr 01, 2009 8:29 pm
tlc
Bike Help Blueing of pipes
Dodgy Z1B 8 287 Tue Mar 24, 2009 10:01 pm
mikey
Regardz
john_roscoe
Bike Help 1973 Z1
Andy T
02GF74
mick z1a
paulstrees
tlc
mikey
Regardz
wilsonsjw11
COME ON......Garry.L wrote:Should be interesting when you go into the shop and ask the sales assistant for a 'Blue Job'.......
This is supposed to be a specialist bike site?????
I'm shocked.
Jimmock.
Jimmock.
Got to disagree that all pipes discolour. It is normally because the bike is running too lean and getting too hot so check your mixtue settings. As you know, original pipes have thicker down tubes than the copies and never seemed to blue. We have fitted lots of copy exhausts and never had then discolour but I know how annoying it must be when they do. Blue job polish will work but unless you address the problem the discolouring will just come back.
Gez
Steve Cooke
paulstrees
GEZ635 wrote:Got to disagree that all pipes discolour. It is normally because the bike is running too lean and getting too hot so check your mixtue settings. As you know, original pipes have thicker down tubes than the copies and never seemed to blue. We have fitted lots of copy exhausts and never had then discolour but I know how annoying it must be when they do. Blue job polish will work but unless you address the problem the discolouring will just come back.
Agree with Ges,I,ve fitted a lot of new replica systems over the last few years and never had a problem,its down to a poor set up and not warming the pipes up a few times before riding
bluing
I fitted replica pipes and before fitting I was advised to soak the insides with used engine oil, the oil burns off quick and leaves an insulating layer which helps prevent blueing - the tip came from a mate who has single skin chrome pipes on his 67 Camaro - apparently its done a lot in the custom car scene
Anyway no blueing as yet
I have also seen blueing on double skin pipes - theyre not beyond discolouration either
