z1a poor compression, time for a rebore
steve r1
#1 PostAuthor: steve r1 » Sat Apr 07, 2012 11:11 am
hi guys,trying to find nos pistons & rings for my z1a, z1 enterprises have them not overly keen on buying from us,import taxes vat,and iffy delivery service is a worry anywhere else i can try?What"s opinion on repros from zpower,cheers
#2 PostAuthor: chrisu » Sat Apr 07, 2012 12:04 pm
I have NEVER had anything but great delivery service from Z1 Enterprises so I wouldn't let that part put you off.
steve r1
#3 PostAuthor: steve r1 » Sat Apr 07, 2012 3:34 pm
not z1 enterprises that worries me,it"s the postal, customs system,heard a few horror stories about slow delivery,
rogz1a
#4 PostAuthor: rogz1a » Sat Apr 07, 2012 4:49 pm
I guess from your title you want oversize pistons/rings. If not I have a complete set of standard rings that have only done 100 miles. I found that my bores were at maximum tollerance so needed a rebore. There's some used pistons which I was told by S.E.P were close to minimum tollerance so I replaced these as well. Any good to you ?
I got new pistons and rings from z1 enterprises. They arrived within 7 days and no problems with customs etc. :wink:
GEZ635
#5 PostAuthor: GEZ635 » Sun Apr 08, 2012 10:37 am
Have you actually measured your bores yet? Badly seated valves will also affect compression!
Gez
steve r1
#6 PostAuthor: steve r1 » Sun Apr 08, 2012 3:51 pm
yes bores checked by zlbman,they were out of tolerance,also confirmed by leakdown test,valves checked too,they were ok.bike has done 43000 on original standard size pistons.Been f---n about for last 6months thinking erratic tickover was carb problem.even with low compression on 2&3 bike seemed okayish at speed,can"t wait to see difference after rebore.
#7 PostAuthor: chrisu » Sun Apr 08, 2012 5:25 pm
Probably best to get the head done while it's apart
