cam clamps
steve bowdler
cam clamps
#1 PostAuthor: steve bowdler » Wed Mar 28, 2012 8:42 pm
Out of curiosity are these interchangable I thought each set was differant or am I talking Bo**ocks :roll:
http://www.ebay.co.uk/itm/KAWASAKI-Z1-Z ... 3f157b580d
#2 PostAuthor: zed1015 » Wed Mar 28, 2012 8:50 pm
They can be used on other heads as long as you know what you are doing.
#3 PostAuthor: chrisu » Thu Mar 29, 2012 8:46 am
looks like they've blasted the white metal bearings as well !!
:shock:
#4 PostAuthor: kev edwards » Thu Mar 29, 2012 12:12 pm
I know these can be used on other heads, but these have had the mating surfaces bead blasted, so based on that reason only i would not use them and would say this particular set needs to go in the bin, i am one of the guys that have reused cam caps on different motors, although they were originally line bored in place, the beauty of cnc machining and tools used for only a limited amount of heads makes it reasonably easy to be able to interchange these caps, although care must be taken that when doing so it does not clamp the cams.
Garn 1
#5 PostAuthor: Garn 1 » Thu Mar 29, 2012 2:29 pm
Kev, you know that I always have respected your opinion, however, that bead blasting would have little or no effect on the dimensions of the clamps.
RegardZ
hillbilly
#6 PostAuthor: hillbilly » Thu Mar 29, 2012 5:02 pm
just put new bearings in,and use. :wink:
Garn 1
#7 PostAuthor: Garn 1 » Thu Mar 29, 2012 9:56 pm
These cam-caps are not interchangeable, however, as Zed1015 says they can be fitted if you know what you are doing! Sometimes you can just fluke it!
#8 PostAuthor: kev edwards » Fri Mar 30, 2012 9:00 am
Without opening up a huge can of worms, in the ad it actually says they have been shot blasted, so even i would not use them, as for the time old debate they are not interchangable my own view is that they were made on very good cnc machinery with very close tolerances and then a bearing shell placed in, which can vary a little in thickness and can also be replaced as an aftermarket part and over a forty year period there has bound to be a few variations in thicknesses, also has someone on the forum actually bought new caps some years ago from kawasaki.
#9 PostAuthor: PAULJAC47 » Fri Mar 30, 2012 7:03 pm
Scrap.... plain and simple!
#10 PostAuthor: zed1015 » Sat Mar 31, 2012 12:58 am
Again! Shot blasted or not, No problem using them if you know what you are doing.
Arm yourself with a surface plate, internal bore gauge,a new set of shells, plastigauge and some wet'n'dry + some patience and a small amount of intelligence = job done.
Very old, done to death subject :roll:
Most shops will tell you it can't be done ONLY because either they couldn't be arsed or the labour could out weigh the cost of a second hand replacement head.
Go to any decent engine reconditioner or proper engineer (not fitter) and they can do it if you are prepared to pay the £££££.
