Ex 4 on 2.5 thou clearance but has a 200 shim fitted. I guess that implies head off time (soon) and slight skim on the valve top? Or has anybody have an alternative solution?
Shim Swap
- rickman CRR
Shim Swap
Does the club still swap shims via Jerry? Need 240, 245 and 265 to give me 2-4 thou clearance.
Contact Jerry for 29mm shim swaps or me if you need the smaller 13mm shims.
Valve tips can be ground by 0.3mm according to the manual, but by a bit more than that if needed.
Some people may have shims as small as 1.80mm I believe these may be from some Yamaha models, so if you can source some, that would keep you on the road for a little longer, before the head has to come off.
Apparently, grinding shims is highly frowned upon.
- rickman CRR
- rickman CRR
