#6 PostAuthor: PAULJAC47 » Wed Mar 21, 2012 9:52 pm
			Castle nut should be on right when looking at bike from rear,threads on bolt should not protrude,poss bike has been over and hanger is bent,rubber bobbins could be compressed if old ones ,new ones you sometimes need to compress to get hanger bolts in.i recently fitted Dremi pipe and found it to be of superior quality to the Z power ones, albeit it seemed to be very slightly wider.When fitting the pipes fit all 4 collets first just rest pipes in these loosely,then fit rear hanger bolts,nip them up then fit front collets and clamps ,stick sealing washers in first with a blob of grease,dont be tempted to run bike up to temp in one go gradually build up temp by running bike slightly longer each time,this stop blueing of headers as long your mix is right.On most bikes the castle nut is very close to the bottom lower pipe.(have fitted a few more than one set like this)
Cheers Paul J
PAULJAC47 on Wed Mar 21, 2012 9:55 pm, edited 1 time in total.
You can't polish a turd, but you can roll it in   glitter
