Does anyone know if there is any difference between the air filter elements on a Z900A4 and a Z1000A1?
Andy
Z900 Air Filter Element
phil churchett
Forgive me if I'm wrong.
Memory ain't what it used to be..........The two aren't interchangeable. Z1000 is around 10mm taller than the Z900 element. Now I think....the Z1000 has a fully recessed tab on top the Z900's is only partly recessed
Begging your pardon sir, but you did say that you'd like .................a green one?
