Z900 Air Filter Element
Hack
#1 PostAuthor: Hack » Mon Jun 11, 2007 4:52 pm
Does anyone know if there is any difference between the air filter elements on a Z900A4 and a Z1000A1?
Andy
phil churchett
#2 PostAuthor: phil churchett » Mon Jun 11, 2007 5:51 pm
Andy,
according to Z Power parts books, Z900A4 is part no;11013 054, Z1000A1 is part no; 11013 063.
I think they are basically the same, except for the top.
Someone on here may be able to shed a bit more light, failing that, ring Dave.
Sorf
#3 PostAuthor: Sorf » Sat Jun 16, 2007 7:21 am
Forgive me if I'm wrong. :oops: Memory ain't what it used to be..........The two aren't interchangeable. Z1000 is around 10mm taller than the Z900 element. Now I think....the Z1000 has a fully recessed tab on top the Z900's is only partly recessed
Begging your pardon sir, but you did say that you'd like .................a green one?
