Mikuni Needle Jet - for UK spec Z1000 MKII
njwmct
#1 PostAuthor: njwmct » Fri Mar 16, 2012 10:48 am
Anyone got a Mikuni Needle jet - 258 O-1
was Kawasaki Part no. 16017-1011
Needs to be in good condition with no wear / pitting of the internal bore.
Cheers.
#2 PostAuthor: z1bman » Fri Mar 16, 2012 1:34 pm
16017-1011 - this part is fitted to this model list
KZ1000-A1 KZ1000 (1977)
KZ1000-A2 KZ1000 (1978)
KZ1000-A2A KZ1000 (1978)
KZ1000-A3 KZ1000 (1979)
KZ1000-A3A KZ1000 (1979)
KZ1000-A4 KZ1000 (1980)
KZ1000-D1 Z1R (1978)
KZ1000-D3 Z1R (1980)
KZ1000-E1 Shaft (1979)
KZ1000-E2 Shaft (1980)
Z1parR
#3 PostAuthor: Z1parR » Sat Mar 17, 2012 10:39 am
What is this then , an emulsion tube or a needle jet or both :??
Always called it an emulsion tube , am i totally confused , what day is it :star
0172 . Geoff Parr
njwmct
#4 PostAuthor: njwmct » Sat Mar 17, 2012 2:09 pm
Hi Geoff,
That's the emulsion tube.
The needle jet is sat above that & is a press fit in the carb body.
When you remove the slide & look down into the carb the needle jet is the brass bit that the needle goes down through.
You tap it from the slide side & it drops out at the bottom of the carb from where you removed the emulsion tube from.
Hopefully the no. on it will be 258 O-1
Nick.
#5 PostAuthor: z1bman » Sat Mar 17, 2012 3:01 pm
no 26 in the picture
Z1parR
#6 PostAuthor: Z1parR » Sat Mar 17, 2012 4:19 pm
Cheers Nick and z1bman i have caught up now and am on the right page :lol:
I have just removed one Nick and its number is 258 0-1 , i'll post all four of them to you on monday ,
choose the one you like best and send the rest back mate .
0172 . Geoff Parr
njwmct
#7 PostAuthor: njwmct » Sat Mar 17, 2012 6:15 pm
Fantastic!
Many thanks.
Users browsing this forum: No registered users and 4 guests
