which Hyd clutch and brake master cylinders?
rpeters
Bristol's "H" Hoarder
#1 PostAuthor: rpeters » Thu Mar 15, 2012 7:57 am
I am looking for matching Hyd clutch and brake levers (with reservoirs) for my MKII project. Can anyone suggest any options, looked at Brembo (frighteningly expensive)....any ideas/pics??
Padders
#2 PostAuthor: Padders » Thu Mar 15, 2012 8:15 am
Hi Rob I have always used ZRX1100 1200 mastercylinders when I have converted my Zeds to Hydraulic clutch. Always available on e bay and retains the mirror fitments.
See my z1000 on the thread below.
http://www.z1ownersclub.co.uk/forum/vie ... =hydraulic
#3 PostAuthor: Ginger Bear » Thu Mar 15, 2012 8:24 am
Rob, I tried a couple of Brembo clutch master cylinders (ex Ducati/Aprilla) & couldn't get 'em to work.
I then used ZX7R clutch & brake master cylinders with remote reservoirs that worked a treat.
I might even have a set if you're interested, along with some stubby style Titax levers. :shock:
# 104
Z.O.A
#4 PostAuthor: Z.O.A » Thu Mar 15, 2012 9:20 am
ZRX 1200 or BANDIT 1200 or OLDER GSXR 1100, I used Bandit 1200 set up, found them more plentiful and at better prices than ZRX ones, Ebay is the place to look.
#5 PostAuthor: chrisu » Thu Mar 15, 2012 9:56 am
i've used ZRX and Bandit ones - both good but I prefer the look of the ZRX ones.
rpeters
#6 PostAuthor: rpeters » Thu Mar 15, 2012 11:22 am
Thanks for the ideas Guys, have you got a pic of the levers Steve...rob
#7 PostAuthor: Ginger Bear » Thu Mar 15, 2012 11:29 am
Very similar to this, same shape, maybe slightly darker in colour.
If your half tempted Rob, I'll dig it all out & take some pic's.
# 104
#8 PostAuthor: zed1015 » Thu Mar 15, 2012 12:33 pm
Also the same nissin parts are used on most kawasakis. ZXR's and Yam YZF750.
Just make sure you get the correct master cylinder bore for twin disc.
On the Drouin i used Aprillia RSV factory Brembo cylinders, coupled with a zxr/zx9 slave the clutch is very light.
#9 PostAuthor: chrisu » Thu Mar 15, 2012 12:33 pm
Image[/img]
#10 PostAuthor: chrisu » Thu Mar 15, 2012 12:35 pm
GSXR master cylinders
I still have them if you're interested.
LondonZ1
#11 PostAuthor: LondonZ1 » Sun Mar 18, 2012 10:11 pm
I have ordered Braking RS radial clutch and brake master cylinders from Talon. They come complete with reservoirs and were not silly money.
http://www.braking.com/Braking/sito/documenti_allegati/103_link_inglese_ONROAD-RS-B1-ENG.pdf
http://www.braking.com/Braking/sito/documenti_allegati/103_link_inglese_RS-C1.pdf
They are special order from Italy, due here in 4 weeks or so.
