I am trying to get a set of unitrack barrels rebored to 1170 which is 2.5mm over.
I cant get anyone around here to do it for love nor money.
I need someone who has a proper re-bore setup not a converted Black and Decker.
Only bloke who said he would said it would take two days with his machine because he can only do 0.5 mm at a time and then has to let it cool down for an hour. Thats five passes at 20 mins each times four bores with and hour between each pass.
The other guy has a hand drill that hangs from the garage roof on a bungy cord and he manually passes it up and down to hone.
The others i have spoken to say that they only do car stuff these days!!!!
Anyone know of a professional in the Hants / Surrey / Berks area who could get it done please.
Many thanks in anticipation.
Good re-bore needed
Good re-bore needed
- Dark Skies
These peeps are in Oxfordshire but you could courier the parts if you didn't fancy making the trip.
http://www.fjpayne.com/machining-servic ... der-blocks
KZ1000-M1 CSR
- DogsbolloxofZ1B
- steve bowdler
