Moriwaki rep
- paul doran
They are extremely gorgeous.
This is from the suppliers site
The pro-fessional bribe from detent systems Rairotec by their sporty design and excellent functionality. The multiple adjustment optimal sitting posture is achieved. Shift and brake levers are double, with high quality ball bearings, mounted. Folding shift and brake pedals can be an extreme cornering. The change of position of the switch plate (left), an inverter circuit is possible. The load-capable, united from high strength aluminum construction high strength with low weight. The original master cylinder can be fitted with an adapter plate (accessory), or use the brake cylinder Rairotec (Art.Nr BRZY050).
The forward controls are supplied with a TÜV certificate.
The forward controls CLASSIK.
Shift and brake levers are equipped with bronze bushings, each storage unit is sealed with two O-rings. This guarantees countless safe and maintenance-free shifting and braking operations.
Complement of rear free milled lightweight base holder with the technically superior foot controls - in addition to better seating position a visual highlight for your motorcycle.
The original master cylinder can still be used.
All parts are available as replacement parts.
paulmceleney
- Chunks
Very indeed Ian...i can see what you mean about it standing up to upright now.
