petrol tank rust treatment
weaver
#1 PostAuthor: weaver » Fri Feb 24, 2012 8:48 pm
my elr has some evidence of rust inside,whats the best treatment for it?
thanks
Keefleaf
#2 PostAuthor: Keefleaf » Fri Feb 24, 2012 10:05 pm
There are a few options,have a look on you tube before you start
I've done the cement mixer/tank with bolts in.Knocks off the loose stuff.
Then Soda Crystals ,5gallons of water/5 tablespoons of Soda C'
Battery charger.negative to bottom of tank/petrol tap mount.
Positive needs piece of metal clipped on and suspended in filler opening.This must not touch bottom or sides. Turn it on.see rust collecting in 10 mins' .
2 hrs ish then disconnect,flush out with a hose pipe.
Plug up tank again( wine cork ),pour in Meth'spirits.this absorbs moisture from inside.
I used "Splosh" from Dragonfly Motorcycles. £25 delivered.
This did two tanks in one hit.
Anyway that's what happened to me after watching all the YouTube clips :|
pertonpc
#3 PostAuthor: pertonpc » Fri Feb 24, 2012 11:26 pm
I use proscale 650 water based rust dissolver.
Works good if you can get it. Some pics of it used hot on you tube but it works normal temp as well.
Walsall Chemical Company make it.
Cheers from Mark
coldsummer
#4 PostAuthor: coldsummer » Fri Feb 24, 2012 11:41 pm
I've had good results with Biorust from C W Wylde.
weaver
#5 PostAuthor: weaver » Sun Feb 26, 2012 2:31 pm
thanks lads,will check these out :wink:
Coxy
#6 PostAuthor: Coxy » Mon Feb 27, 2012 12:07 am
Had my KH250 tank treated and lined at Ormskirk Motorcycles not too far from you.
Z1a, Z900-A4, H2b, S3a, KH250b3, KH250b4, ZX10r
750steve
#7 PostAuthor: 750steve » Mon Mar 05, 2012 1:33 pm
Soda Crystals? Baking Soda, Caustic Soda or something else?
oldzed
#8 PostAuthor: oldzed » Tue Mar 06, 2012 1:30 am
I used table vinegar
left it in for 2 days
cleaned all the rust/sludge out then rinsed it with cellulose thinners
