piston sizes
hillbilly
piston sizes
#1 PostAuthor: hillbilly » Tue Feb 14, 2012 5:42 pm
a bit of info needed lads and lasses,ive just measured a standard piston(903cc)its about 65.16mm.ive been offered some pistons at 67.05mm.what cc would they be for.
paulmceleney
Chunks
#2 PostAuthor: paulmceleney » Tue Feb 14, 2012 5:49 pm
1mm is about 30cc
Gus
#3 PostAuthor: Gus » Tue Feb 14, 2012 5:57 pm
According to Wiseco
70mm is 1015
71mm is 1045
"Set the GRINDER on it"
ruffle
#4 PostAuthor: ruffle » Tue Feb 14, 2012 6:21 pm
Short answer: around 950cc
Long answer:
It's the area of the bore times the swept volume
Code: Select all
(((bore/2)^2* pi) * 4) * stroke
so for a standard 6.6cm bore (piston is a bit less) and standard 6.6cm stroke....
Code: Select all
(((6.6/2)^2*3.1415)*4)*6.6 = 903.16 cc
for your 6.7cm pistons its...
Code: Select all
(((6.7/2)^2*3.1415)*4)*6.6 = 930.74 cc
but that's not allowing for any piston/bore clearance so add 1 mm (not actually sure what the bore should be for your pistons) and that makes it:
Code: Select all
(((6.8/2)^2*3.1415)*4)*6.6 = 958.73 cc
hillbilly
#5 PostAuthor: hillbilly » Tue Feb 14, 2012 6:24 pm
so would that make them one mm overbored. :?:
#6 PostAuthor: zed1015 » Tue Feb 14, 2012 6:26 pm
Yes.
hillbilly
#7 PostAuthor: hillbilly » Tue Feb 14, 2012 6:32 pm
cheers lads,it was clear as mud at first. :lol:
ruffle
#8 PostAuthor: ruffle » Tue Feb 14, 2012 6:40 pm
You'll still need to find out what the right bore is for those pistons (assuming they're not NOS with known part numbers).
Wiseco talk about bore size not piston diameter; so their 70mm/1015cc pistons are not actually 70mm wide. The 70mm is what bore the cylinders need to suit those pistons.
hillbilly
#9 PostAuthor: hillbilly » Tue Feb 14, 2012 6:52 pm
i understand that ruffle,my mate has lent me some barrels that are one mm overbored,so can take a measurement off them to get correct bore.cheers. :wink:i think they will be two mm overbore,and not one,as the piston i have here is one mm over,and reads 66.9 mm. :?:
#10 PostAuthor: zed1015 » Tue Feb 14, 2012 7:24 pm
The bore needs to be the same dia as the piston and then honed to give the correct clearance . Simple.
garyd
#11 PostAuthor: garyd » Tue Feb 14, 2012 7:39 pm
I do recall some 'big bores' were 960. Not very popular as the engine could easily take more.
What make of piston are they?
hillbilly
#12 PostAuthor: hillbilly » Tue Feb 14, 2012 7:43 pm
waiting to find out what make they are. :?: :??
steve.w
#13 PostAuthor: steve.w » Tue Feb 14, 2012 9:20 pm
hillbilly wrote:waiting to find out what make they are. :?: :??
genuine kwak i think :D
hillbilly
#14 PostAuthor: hillbilly » Tue Feb 14, 2012 9:37 pm
cheers steve, :wink:
