cleaning powder coating
Z1Barrie
#1 PostAuthor: Z1Barrie » Tue Jul 25, 2006 10:24 pm
what is the best way to clean a powder coated frame ect.. is there some special polish or do ya have to just grim and bear it.. the frame was done about 8 years ago and it looks a little dull hence it looks tatty
cheers
barrie
#2 PostAuthor: Rich » Wed Jul 26, 2006 5:16 am
If it's just looking dull, not chipped and you want it done the same colour try T-Cut, I have taken scratches out with it and use it to polish my frame. Otherwise I have heard than Nitromors works but have not tried it.
Padders
#3 PostAuthor: Padders » Wed Jul 26, 2006 6:24 am
Nitro works but just do a part of the frame at a time. It takes that top surface dullness off but only leave it a short time. Not tried T Cut before will give that a go this weekend.
Cheers Ian.
#4 PostAuthor: Rich » Wed Jul 26, 2006 5:52 pm
P.S. the nitromors was meant to strip the stuff off completely.
T-cut to polish.
Padders
#5 PostAuthor: Padders » Wed Jul 26, 2006 6:11 pm
Rich if you put a small amount on leave it for a short time and clean off with Crystal Glo it take's out all the top grime and those small rust spots. Be careful on the time you leave it on though and always err on the side of caution. I do not want loads of emails from guys with stripped frames! Before I try the t cut does it leave any scratch's on the surface. I have avoided it in the past a I assumed it worked by cutting into a surface.
Cheers Ian.
#6 PostAuthor: Rich » Wed Jul 26, 2006 8:46 pm
Ian - All polishes remove surface material, most scratches are caused by the cloth used as opposed to the polish. Don't use your daughters best sequinned top, an old t-shirt is usually the best, don't start off with the cruddy dry bit from the neck of the bottle and wash the frame first to get the grit off it. You should be able to achieve a finish at least as good if not better than the original.
Users browsing this forum: Google [Bot] and 20 guests
