On a '78 Z1R, where are the breather hoses from carbs 2 & 4 meant to end up? Should they just flap about in the general vacinity of the airbox or do they have a 'proper' home?
TIA.
Z1-R (D1) Carb breather hose routing?
Definitely a proper home.
most likely up to each side by the plastic baffle plate below the rear of the tank - or could be down between airbox and side panel.
Someone will be here soon to tell you.
www.cmsnl.com says it should be 5mm inner diameter, 8mm outer diameter and 550mm in length to route properly.
part no. is 92059-1028 and they are still avail at 12 euro if you want gen items
POST
Mine just go past the end of the tank on top of the airbox lid clipped in their clip.
But there are only two, or do you mean the bowl over flow pipes ,they go into a rubber ring round the os rear engine mount and down the back of the engine.
Ted
Ted
"Work this is why I did it"
"I've had more minutes than I have left"
Z1R D1
Granada
vantastic Transit........
KLE650
Z1R D1
Granada
KLE650
