size 20 pilot jets
size 20 pilot jets
#1 PostAuthor: chrisu » Sun Feb 05, 2012 11:07 am
has anyone got a set of 4 size 20 pilot jets they want to part with. Happy to swap for a set of 17.5s................
#2 PostAuthor: Pigford » Sun Feb 05, 2012 1:39 pm
If no luck here - Allens Performance stock them :wink:
Steve S
#3 PostAuthor: Steve S » Sun Feb 05, 2012 5:33 pm
I have four new new #20 pilot jets left over from a Keyster refurb kit if they are any good to you? what carbs are they for? kit was for Z1A,can post picture if unsure :?:
#4 PostAuthor: chrisu » Mon Feb 06, 2012 2:32 pm
z1000 28mm carbs but I think they're all the same.
If so would be great.
Steve S
#5 PostAuthor: Steve S » Mon Feb 06, 2012 8:33 pm
Heres a picture of them Chris,if they are ok just pm me your details and I will send them over to you.
#6 PostAuthor: chrisu » Tue Feb 07, 2012 9:52 am
yup - they certinly look the same - will send you a pm........
Jeff Saunders
#7 PostAuthor: Jeff Saunders » Wed Feb 08, 2012 12:18 am
the ones in the picture will ONLY fit the 73 and early 74 Z1 carbs.
They are VM28/213 series - unique to the early Z1's. The VM28/486 series is what you need.
The easy way to tell them apart is the 6 bleed holes in the early ones and 8 in the later ones found on all other VM26 and VM28 carbs.
Steve S
#8 PostAuthor: Steve S » Wed Feb 08, 2012 10:56 am
Chrisu have a pm
#9 PostAuthor: chrisu » Wed Feb 08, 2012 7:06 pm
Jeff,
Thanks ........ I think............. :)
well you learn something new every day.
Steve - thank you very much for your offer but I guess I'll be dipping inti my wallet for allens or z power...............
#10 PostAuthor: Pigford » Wed Feb 08, 2012 7:55 pm
Steve S
#11 PostAuthor: Steve S » Thu Feb 09, 2012 10:21 am
No Problem Chris,sorry you couldn,t use them........Thanks for picking this up Jeff and useful information for us all :D
