Z1000A2 Fork Rebuild
Islander
#1 PostAuthor: Islander » Fri Feb 03, 2012 5:14 pm
I have got stuck we the forks off my bike I cannot remove the bottom allen bolt to split the forks has anyone got any bright ideas to stop the inner damper sping. I have tried the old broom hand trick but no go, except a moan from the wife about oil on her broom handle.
LTD Project
#2 PostAuthor: LTD Project » Fri Feb 03, 2012 5:42 pm
I have been there before...... :roll:
I overcame the issue after buying one of those cheap compressor units from Aldi. Also bought a air wrench amongst over things to go with it.
Anyway, said air wrench with the right hex bit got them out in seconds. Put a wry smile on my face thinking about the time and effort I had expended on the job before the air wrench came along.....
If this isn't an option for you, you could take your forks and the right bits down to your local garage, I'm sure they would help...
Good luck
KZ1000 B4 on the road, KZ1000 B4 under serious restoration, KZ1000 B3 waiting it's turn.
GB's old snotter in the operating theatre at present!
#3 PostAuthor: PAULJAC47 » Fri Feb 03, 2012 5:44 pm
Think thats a 17mm head use a piece of threaded rod with a couple of nuts the right size locked together or better still welded on clamp rod in vice..
Cheers Paul J
#4 PostAuthor: Pigford » Fri Feb 03, 2012 6:46 pm
Whittle the end of a wooden broom handle at 45degs - knock it in firmly with a mallet - clamp broom handle in a vice - this will hold damper (without harming it) and enable allen bolt to be undone - SIMPLES :wink:
#5 PostAuthor: paul doran » Fri Feb 03, 2012 7:02 pm
or if You have a blow torch gently heat the head of allen screw
works every time for Me
Z.O.A
#6 PostAuthor: Z.O.A » Fri Feb 03, 2012 7:25 pm
I used one of those "Gator grip" universal sockets on a long 3/8 extension bar, you know the ones with all the pins inside to grip broken bolt heads etc.
Here's a link to similar type, worked perfect, no hassle on the few sets of forks I've rebuilt so far.
http://www.ebay.co.uk/itm/Gator-Grip-ET ... 20c191cb10
Islander
#7 PostAuthor: Islander » Fri Feb 03, 2012 7:34 pm
Many thanks for your ideas off to garage now will be back soon!!!!!
#8 PostAuthor: Al » Fri Feb 03, 2012 7:44 pm
3/8 drive socket extensions worked for me!
#9 PostAuthor: Pigford » Fri Feb 03, 2012 7:48 pm
Zorded wins :wink:
#10 PostAuthor: Al » Fri Feb 03, 2012 8:01 pm
Watdo i get watdo i get??????? :)
#11 PostAuthor: Pigford » Fri Feb 03, 2012 8:18 pm
zorded wrote:Watdo i get watdo i get??????? :)
......smug satisfaction Al :wink:
#12 PostAuthor: Al » Fri Feb 03, 2012 8:20 pm
Smug all over...... just found a job after being un-employed for the last two years!!
AL (working bloke)
#13 PostAuthor: Pigford » Fri Feb 03, 2012 8:39 pm
zorded wrote:Smug all over...... just found a job after being un-employed for the last two years!!
AL (working bloke)
Made up for you matey :P
PJ
#14 PostAuthor: PJ » Fri Feb 03, 2012 9:17 pm
AL (working bloke)
Contests on the job news Al
#15 PostAuthor: Al » Fri Feb 03, 2012 9:38 pm
Cheers Piggy and Paul i'll try not to nob this one up!
http://www.fhellis.com/fabrication.php
