Before you do anything else you MUST take the cam cover off & check your valves. A stuck valve will be visible as being much lower than the rest when the cam lobe is point away from it.
Turn the engine over slowly, with a spanner on the end of the crank. You've almost certainly bent at least one valve !
HELP ! Wont start. Im bloody jinxed.
Pigford wrote:andyb1962 wrote:I am open to advice on that one Kev
but a soft link is certainly easier. has anyone had any problems with one?
Nowt wrong with a soft link - if done right - not too tight or you'll be back where you started![]()
Real p*ss*r though
Good news at last then ........ soft link sounds the way to go then.
Should be back running in a month or so. Thanx
Andy
As piggy says if done propperly the soft links are good, hopefully it will be running again soon, i have a few of the cam cap studs kicking around if you want them, the ones in the head are the first set i made i did not change them as they done the job and run for the 5/6 years i had it on them, i made some more and found some of them the other day, i still wish i had kept the old nail myself.
kev edwards wrote: i still wish i had kept the old nail myself.
Me too sometimes Kev
Only jokin me and the "old nail" are starting to bond. But i didnt intend to get so intimate with her so early in our relationship.
Andy
