Which later parts can I use in a Z1 engine?
malmojoe
#1 PostAuthor: malmojoe » Thu Jan 26, 2012 1:28 pm
I need gearbox/crank/everything to put into a Z1 casing. Can I use any parts from a Z900 or do I need to find Z1,a,b engine parts?
many thanks oh knowledgeable ones.
:wink:
Keefleaf
#2 PostAuthor: Keefleaf » Thu Jan 26, 2012 2:09 pm
Fairly sure it all drops in ? 99.9% sure?
#3 PostAuthor: zed1015 » Thu Jan 26, 2012 4:06 pm
All parts right up to mk2 will drop straight in.
All 900's are basically the same.
1000's have heavier cranks .
mk2's have a few more slight differences (mainly the crank, cam sprockets and alternator) but overall essentially the same motor.
Re: Which later parts can I use in a Z1 engine?
#4 PostAuthor: chrisu » Thu Jan 26, 2012 4:44 pm
malmojoe wrote:I need gearbox/crank/everything to put into a Z1 casing. Can I use any parts from a Z900 or do I need to find Z1,a,b engine parts?
:wink:
What do you need - I have most engine internals/clutches/gearboxes/cranks etc.
malmojoe
#5 PostAuthor: malmojoe » Thu Jan 26, 2012 7:35 pm
Thanks again, all good news to me. :lol:
Chrisu, what ever you have I probably need it. What I have at the moment is top and bottom casing, cylinder(see my other thread) and head.
Was hoping to find a doner engine but no luck so far so was going to start picking up pieces as they come up on ebay, that why I was asking what would fit. Just PM me with any pieces you have for sale.
cheers guys. I am definitely going to put up a project thread.
steve bowdler
#6 PostAuthor: steve bowdler » Thu Jan 26, 2012 7:54 pm
malmojoe
#7 PostAuthor: malmojoe » Thu Jan 26, 2012 7:57 pm
cheers Steve, that would do it :lol:
Garn 1
#8 PostAuthor: Garn 1 » Fri Jan 27, 2012 11:26 am
MalmoJoe, the only engine part I know that is not interchangeable from the Z900, z1000, to the Z1, is the 4 coil hair spring, that is on the selector lever. The later lower cases have provision for this extra coil by a recess (groove), as opposed to the three coil.
RegardZ
#9 PostAuthor: chrisu » Fri Jan 27, 2012 4:13 pm
let me know how you get on buying the engine - if you still need bits let me know.
