Harris Magnum 1
Slow progress at the moment........ Now the 5/8" off-set drive sprox are done & collected from Talon,
I asked them to make me up a special sprocket adaptor coz I need a total of 28mm off-set for the 190 section tyre fitted on the Dymag.
I need to set the rear wheel sprox in by 12mm, so they will make a plate to fit where the sprox should live and then I can fit an "off-the-shelf" item to the inboard side of that - and voila, sorted
Once thats done I'll get some 530 H/D chain and the drive line will be complete
All in the c&s effort will be just over £200
I've contacted a chap in Yeovil who powder coated my Mk.II SPrinter and he can do me frame, yokes, s/stand & mounting piece for about £150, so should get that down to him next week - 7 - 10 day turn-around
neilbarrett
paint code
Here you go this is what i have used.
EL KAW 3B VERDE from paints4u.com
[img][img]http://i223.photobucket.com/albums/dd291/kwackerz1/pb2003.jpg[/img][/img]
- RALPHARAMA
I always feared painting; it is challenging, but well worth the effort. I felt soo good after I did my first paint job. Give it a go.
Ralph Ferrand
vduk wrote:I always feared painting; it is challenging, but well worth the effort. I felt soo good after I did my first paint job. Give it a go.
Trouble is (many-fold).... I've got no equipment;
No spray gun
No compressor
No paint
No room
No talent
No idea
Some may recall my attempt on the Mk.II, with "rattle cans"
'Nuff siad.......
So, finally got the sprocket adaptor from TALON yesterday..... to be polished within an inch of its life
So thats brung it in 12mm - and the drive sprox is out by 5/8" - Jobs a goodun
The adaptor allows fitting of a standard "off-the-shelf" sprox - in this case one for a VRF800
- paul doran
paul doran wrote:lots of ironing I take it Mark
.... my penance is sorting out the w/heater this weekend..... My lads coming up (with his mate) to fit a new mains board & electric water heater, pressurise the system and fit a new pump & 3-way port, etc
Timed it well though, the heating oil is just running out
Following weekend on a short break to Brixham (Devon) for Valentines
