Tank repair
gray
Tank repair
#1 PostAuthor: gray » Wed Jan 18, 2012 7:35 pm
I'm putting an old trail bike back ( XL 185) on the road , it's been laid up 15 years. Tank looked all right till I had it blast cleaned and looks like paint was all that was keeping petrol in- half a dozen tiny pinholes , on both sides of the base.
This is going to be my "fishing bike" going offroad trout fishing in the Highlands. Not a pristine restoration.
I was thinking of degreasing it thoroughly, using some Araldite Rapid Steel on the outside , and then getting some of that Caswell tank sealer on the inside.
But am I wasting my time :?:
Presumably welding isn't likely to be easy as the metal is thin and difficult to work and get a petroltight seal. Brazing similarly.
Anyone found any other solutions ? second-hand ones are rare.
gray
Jumbo
#2 PostAuthor: Jumbo » Wed Jan 18, 2012 7:58 pm
I had a rusty tank with only one pin hole but sealed the tank with POR 15. It is good stuff !!
LE to JOG on a z900
P.U.M.
#3 PostAuthor: z1bman » Wed Jan 18, 2012 8:05 pm
you can try lead loading if you want to do the job yourself but you must make sure the tank is completely cleaned + de gassed. to de gas clean it first then run a piece of hose from your car exhaust into the filler cap of you bike tank leave it running for about 15 minutes this should neutralise all the flammable gasses
guide to lead loading
http://freespace.virgin.net/tommy.sandham/leading.htm
Flying Tiger
Ted's Biatch
#4 PostAuthor: Flying Tiger » Wed Jan 18, 2012 8:08 pm
Pin holes are a sign of rust, usually a few pin holes on the outside can mean lots of rust on the inside, and not worth repairing :(
Some choices are brazing as you mentioned, lead loading or soldering, hollow the area out and make sure you take the metal back bright and clean before any work
Remember to purge the tank of any petrol fumes before or you might get a big bang :lol:
#5 PostAuthor: Ginger Bear » Wed Jan 18, 2012 8:10 pm
Gray, I think if you can get one of the newer 'ethanol proof' sealers/liners you should be ok.
I know there have been various rust removal solutions posted before, but I find this stuff amazing...... just leave it in long enough. http://www.cwylde.co.uk/product.php?xProd=2262
# 104
Flying Tiger
Ted's Biatch
#6 PostAuthor: Flying Tiger » Wed Jan 18, 2012 8:11 pm
Oh and as mentioned use sealer as a secondary measure! be sure to use one designed for the new higher ethanol percentage in petrol!
Flying Tiger
Ted's Biatch
#7 PostAuthor: Flying Tiger » Wed Jan 18, 2012 8:13 pm
Beat me to it GB! :D
shaggy
#8 PostAuthor: shaggy » Wed Jan 18, 2012 10:04 pm
jUST REPAIRED A TANK PLASTIC METAL OUTSIDE AND POR15 DID THE JOB
#9 PostAuthor: Ginger Bear » Wed Jan 18, 2012 10:30 pm
Flying Tiger wrote:Beat me to it GB! :D
Not called 'Quick Draw GB' for nothing! :sou
# 104
#10 PostAuthor: zed1015 » Thu Jan 19, 2012 10:54 am
Only one way to do it in my eyes.
Chop out the rust and weld in a new piece.
Any good welder should be able to do it and it will not leak.
All these sealers are ultmately a short term solution that will not stop the rot.
davy thomson
#11 PostAuthor: davy thomson » Thu Jan 19, 2012 11:35 am
zed1015 wrote:Only one way to do it in my eyes.
That was my thughts on this, no point covering up rust it allways finds its way to the surface, would a XL250 TANK FIT? or a plastic Moto x one.?
if you have want Gray send it up to me and I will fix it for you.
1000 posts reached that will do for me,over and out.been fun.
gray
#12 PostAuthor: gray » Sat Jan 21, 2012 7:49 pm
plenty of good ideas there lads - thanks
I'm not a welder so I can't tell just by looking and feeling if something's too far gone. My amateur level of expertise would be if you can get a hand thru it, it's probably scrap.
(Some would say if it was a H~#*a it was scrap already)
Can I post it to you Davy for your expert opinion on it? I've given it a coating of red oxide in the meantime till I decided what to do. PM me with an address if the offer's still on.
gray
Robw
#13 PostAuthor: Robw » Sun Jan 22, 2012 12:05 pm
On my old LC I used JB weld to fill in a pin prick hole and it was still okay after 4 years. I rubbed down the area until it was shiny and ensured it was spotlessly clean and applied the JB weld, I left it for a few days to ensure it was dry. I would also put POR 15 in it so that any rust inside doesnt get into your carbs.
Rob
davy thomson
#14 PostAuthor: davy thomson » Sun Jan 22, 2012 2:29 pm
You have a PM gray.
davy thomson
#15 PostAuthor: davy thomson » Wed Apr 25, 2012 11:05 am
There you go Gray, brought back from the dead.your tea bag tank.Image
