Not that I'm going to do this...but it was raised in conversation with a mate.
I'm guessing that the engine isn't a probalem. It would be the swinging arm pivot is the issue.
Anyone tried?
Can a 1000ST be fitted with a chain drive engine?
I am toying with the idea of doing this next year.
I was planning to exchange the gearbox internals and the two outer sprocket covers on the existing thou engine
The advantage would be that any arm would fit the back and spacing the wheel to sit centrally should be easy.
The other advantage is I already have an ST
If I go ahead I will let you all know so you can slate me
Yes
The crankcases are the same as the z1r (D3) and z1000 (G1) classic,
so many of the gearclusters are a straight swap
You also need to change the inner sprocket cover and the outer cover.
I also believe there are a couple of other minor mods required for the gearlever return spring.
I suppose it could be a cheap way to fix an engine as the ST parts are cheaper in general.
