Garn 1 wrote:Steve, I wouldn't hesitate to use 20 weight. I used to alway use 10 or 15, sometimes I would mix 75%- 20 and 25%-10. I found, with these older forks, 20 is a min.
Regarding capacity of each leg, it is 161cc.
RegardZ
Thanks again Garn, I replaced the oil two years ago using 10 grade I think but its always felt a bit harsh and reluctant to turn so i,m sure it can be improved on.Also since riding my Kh250 although a lot lighter the front end handling of the Zed felt awful compared to it.
I have just upgraded the front tyre and a fork oil change should help also.
Then hopefully I can keep up with a couple of Z900,s on the winding stuff (you know who you are)
Best regards
Steve
