modern front mud Gard
zman
#1 PostAuthor: zman » Sun Jan 01, 2012 5:02 pm
im looking for a more modern front mudguard for my z900.does any one know what might fit :?:
thanks
keep thoses wheels turning
pertonpc
#2 PostAuthor: pertonpc » Sun Jan 01, 2012 10:37 pm
If you are not using a fork brace be a bit careful...
the standard fender has a reinforced section inside between the forks which reduces flexing - a pretty modern plastic one, or a cheap chrome one with only one layer of metal, would not do the job.
Good luck with the search from Mark
zman
#3 PostAuthor: zman » Mon Jan 02, 2012 11:55 am
Thanks mark.
Ive got a really good brace so no probs there.
i like the shape of the Z750 but don't know if i can make it fit :?:
#4 PostAuthor: ADRIAN H » Mon Jan 02, 2012 11:57 am
I am looking at the new Triumph Bonneville, Thruxton, Scrambler - front mudguard, (as they run 100/90x19 tyres).
But I need to check a few dimensions down at local dealer, as I am sure I will have to make a special mounting/ support bracket to get it to fit.
Serps
#5 PostAuthor: Serps » Mon Jan 02, 2012 12:39 pm
Zman, are you talking about a current z750 ?
If you are I will have a look and measure as I have a. 2010 model
Paul
zman
#6 PostAuthor: zman » Mon Jan 02, 2012 1:57 pm
Yes paul.
not sure how it would fix.
Do you have both so you could check before i buy something thats no good :?: Thanks
Serps
#7 PostAuthor: Serps » Mon Jan 02, 2012 2:49 pm
Had a measure and I don't think it will fit, the 750 is 6" wide between the forks, the z900 is 5".
You could butcher the mudgard to fit but I think that would ruin it and look pants. You would also need to put the callipers behind the forks.
Best bet is to find something 5" wide.
#8 PostAuthor: Ginger Bear » Mon Jan 02, 2012 8:00 pm
I have an XJR 400 Mudguard on this, I'll try & measure the width tomorrow.
# 104
#9 PostAuthor: ADRIAN H » Mon Jan 02, 2012 8:52 pm
Could try one of these. (black, they also do a red one).
http://www.patternbikeparts.com/product ... uctID=4259
