FUEL PUMP PIPE B1 B2 WANTED P/NO 92059-1165
Padders
#1 PostAuthor: Padders » Sun Jan 01, 2012 9:28 am
Morning all,
I am looking to buy the pipe/fuel line that comes off the left hand side of the fuel pump and goes to the fuel filter. When I bought my B1 the last owner had out an inline fuel filter on it but I now have a new original filter so need this pipe. It is unique in that it starts out with a larger diameter outlet from the fuel pump then reduces in internal size to fit onto the fuel filter.
Last bit I need before completeing the fuel injection part of my rebuild.
All you guys that have converted to carbs have you still got the old pipe on the pump.
big green bus
#2 PostAuthor: big green bus » Sun Jan 01, 2012 12:07 pm
will have a look
mattc
#3 PostAuthor: mattc » Sun Jan 01, 2012 1:03 pm
Ian,
I appear to have all/most of the bits for B1 injection system....never going to use so you can have what you want. On parts diag this pipe is shown as quite short but on bike is longer as pump below/in front of battery box and filter under LH side panel. Does that sound right to you?
Matt
Matt C
Z1000J2 / ZRX1200R / Z650B1 / GPz1100B1 x 2
Padders
#4 PostAuthor: Padders » Sun Jan 01, 2012 1:20 pm
Thats just right Matt as per photo below i'll drop you a pm with my contact details
rpeters
Bristol's "H" Hoarder
#5 PostAuthor: rpeters » Mon Jan 02, 2012 8:06 am
Hey Matt, dont suppose you have a Fuel pump going spare?? :D :D Rob
mattc
#6 PostAuthor: mattc » Mon Jan 02, 2012 8:14 am
Rob,
I am stripping the parts off a frame later today and have given Ian first dibs on the fuel system. If he decides he does not want the pump then you can have it.
Matt
Matt C
Padders
#7 PostAuthor: Padders » Mon Jan 02, 2012 5:22 pm
Matt if Rob needs the pump to get his bike on the road then no problem I was just looking to have a spare just in case I needed it in the future.
mattc
#8 PostAuthor: mattc » Mon Jan 02, 2012 5:50 pm
rpeters wrote:Hey Matt, dont suppose you have a Fuel pump going spare?? :D :D Rob
Rob, Ian ok the pump goes to you so will send you a PM.
Matt
Matt C
