By pass the side stand cut out switch - which wires
Plumba 54
#16 PostAuthor: Plumba 54 » Thu Jul 13, 2006 8:19 pm
loggin in
Plumba 54
#17 PostAuthor: Plumba 54 » Thu Jul 20, 2006 7:10 pm
LOGGIN IN
#18 PostAuthor: Rich » Fri Jul 21, 2006 6:26 pm
Have you done testing and logggin in yet? If the two black ones are the feed to the starter relay what are the others for?
Plumba 54
#19 PostAuthor: Plumba 54 » Fri Jul 21, 2006 8:51 pm
No idea what the other 2 wires are for,bikes still in bits as mate spraying it is taking longer than expected.
Probably hold the whole bike together and when i do get it together and fire it up the wheels will fall off.
Test/loggin in is the only way i can get on here so i just keep using the old thread.
#20 PostAuthor: Rich » Sat Jul 22, 2006 6:30 pm
They may be the tilt switch, when you go round a corner and lean too far (5' from vertical) an electric shock is sent via the petrol tank to let you know the angle of lean is getting near critical.
Makes your bo**ocks hurt but it sure saves on the laundry bills!
Plumba 54
#21 PostAuthor: Plumba 54 » Sun Jul 23, 2006 9:02 pm
That must be some odd contraption unique to your bike to fulfil one of your stranger fetishes Rich.
#22 PostAuthor: Rich » Tue Jul 25, 2006 5:17 am
I think it must be, luckily I haven't got a sidestand switch!!!
Plumba 54
#23 PostAuthor: Plumba 54 » Tue Jul 25, 2006 8:53 pm
neither have i any more!
Plumba 54
#24 PostAuthor: Plumba 54 » Thu Jul 27, 2006 8:36 pm
loggin in
