Marve's BiTsA Z1000j3
Well, It was nice to meet guyzed and garyd at kempton nice to put faces's to the names so to speak !
Any way got my bandit wheel " Thanks gary " and it goes in with room to spare NICE and most importantly it looks PHAAT !! lol just gotta have a look at the wheel aligment
Got stuck into the wiringing as well pulling my f..king hair out arrrrhhhhhhhh , that little moan aside i sourced the problem and now the motor turns over *started to dance like a school boy * on the button no vrrrrmmmmm vrmmmmm yet didnt get that far as it started raining lol
Had a job cancel today so it gave me a chance to get out in the garden in the day light and get some work done .........
First up i had a quick look at the wheel aligment with my rather crude poles
dont look to sad and i had it pretty much there within 1mm-2mm
( Pics are SH1TE but you get my gist )
Then i thought what the hell, Lets get her running finished off the basic electrics ( just lights, Bandit ignition and clocks left ) Pulled the plugs * SPARKING *
So with that i filled the carbs with petrol and gave it a few turns nearly gave up, But she went vrmmmmmmm pop pop vrmmmmm .
A little rough but she runs carbs well need a basic set up
Looks a little lean to me ????
Also going to not use the standard foot plates and use these bad boys
Guys just so i dont flood up the bike help section
im running 36mm mikuni flatslide's with a gpz1100 engine and bitza of an exhaust
Just because it was a bit of a mare to start and was reluctant to rev up if you bliped the throttle and was poping and coughing about and didnt really want to idle but it was fireing on all 4 pots .. But it hadent run for nearly a year !
Now bearing in mind ive never checked these carbs or there settings
What would be a good sort of setup to start with on the carbs ie ......
main jets
slow running jets
mixture screw setting
and needle position
Many thanks guys
main jets
slow running jets
and needle position
Many thanks guys
My other half gave me a camera to take some pics of my bike for you guys aint she sweet !
Been busy tackleing the wiring mess i let my self in for bandit clocks and ignition all wired up And working might i ad havent tested the rev counter as im checking the carb seting over !
Headlight on and working
Battery box sort of finished
Rear wheel put in needs final alignment but its almost there
Also had a look at the rearsets only problem is the rear brake master cyclinder is going to be laying right under my side panel ???
I got the bottom hole lined up with original mount and drilled the other hole straight through the original foot rest hanger ( AS A TEMP FIX)
Slowly coming together im Planning on getting this as far done as i can so can cruise around summer time on it , I wont hold me breath !
Good stuff Lee.
Looking at that rear master cylinder mount, it probably won't be in the right position/angle once the brake pedal is in the right place.
Shouldn't be too hard to make another mount from some ally bar/plate (5mm?) that will mount the rear master in a more upright position, using the original rearset mounts.
GB I was thinking about using some 10mm alloy and standing the mastercyclinde upright and bringing the pegs futher forward , to bring my knee's up and feet forward !
And im going to have the street baffle out well spotted rich ! Cut the baffle out and replace with some perferated tube and of course exhaust wadding !
