Air Filter
Kerrigan
#1 PostAuthor: Kerrigan » Wed Jul 19, 2006 9:53 pm
I need some Z900 advice guys.
How easy is it to clean the standard air filter?
When the Haynes manual says you can clean it with petrol, does that mean for oily deposits, or just general dirt?
Or is it just better to get a new one?
Also, what is the other filter type thing in the circular plastic container that fits next to the filter box, where the air is drawn through?
Does that have to be cleaned?
I saw that Z1 Enterprises in the States recommend a K&N performance air filter that fits in the standard air box....anybody using one of these and are they ok?
big green bus
#2 PostAuthor: big green bus » Wed Jul 19, 2006 11:31 pm
stick with the standard filter k&n's are a piss on you need to look after them which nobody does. just use a air line to blow the filter out, remember to blow from the inside out (off the bike)
Garn 1
#3 PostAuthor: Garn 1 » Thu Jul 20, 2006 10:49 am
Kerrigan, part of your question "what is the other filter type thing in the circular plastic container that fits next to the filter box, where the air is drawn through?"
That item is a silencer, it is usually missing and it isn't really missed! That filter like internal lining, you see, is just insulation to quiten the sucking noise at the inlet.
steve bowdler
#4 PostAuthor: steve bowdler » Thu Jul 20, 2006 7:45 pm
Good old E-Bay Item number: 290007369292 K+N air filter if you fancy one
Kerrigan
#5 PostAuthor: Kerrigan » Thu Jul 20, 2006 10:10 pm
Thanks chaps, I'll get the filter out and take it up to the local petrol station air line.
Users browsing this forum: Google [Bot] and 20 guests
