Royalratch wrote:All useful stuff!
The wiring should deffo be so that it can't start in gear - but I won't have a neutral light - no clocks. But that doesn't mean I can't run the switch right?
That's right Ratch..... You could still use the switch.
Rich wrote:Yoy need a rose joint on the other end as well (sperical rod end bearing) check it isn't a LH thread. For the arm you need something like that:
http://www.ebay.co.uk/itm/Suzuki-RGV250 ... 4cf8704d53
I think R1 ones fit Z1000 splines if I remember right but check to make sure before paying for one. GPZ1100 linkage will do it, Other than that Harris will sell you one or get a normal gearlever cut it off about a inch long drill a hole in it and mount it at right angles.
Users browsing this forum: Bing [Bot] and 7 guests
