Oil drain plug siezed
hillbilly
#16 PostAuthor: hillbilly » Sun Dec 04, 2011 6:44 am
feck sake ,take the thing of,send it to me,and ile send you a good one back.
ukcoupe
#17 PostAuthor: ukcoupe » Sun Dec 04, 2011 9:37 am
Andy,
this is what you want:
http://www.machinemart.co.uk/shop/searc ... ory/page/1
I had exactly the same problem and one of these babies had the drain plug off in 5 seconds after me trying everything.
You'll probably need a fairly long breaker bar type handle to shift it, but they work brilliantly.
I bought just the expansion set of sockets by the way, one of them fitted perfectly, but if your nut is totally rounded, the smaller 16mm one might be better.
Great bit of kit, but I did have to replace my drain plug from ZPower though!
good luck,
Chris
#18 PostAuthor: z1bman » Tue Dec 06, 2011 9:35 pm
that looks a very handy bit of kit i will be investing in both kits for myself
RB
Mine's a triple!
#19 PostAuthor: RB » Tue Dec 06, 2011 10:35 pm
Jeez, just drop the motor out and send it down to me, I got these H2 Cylinders off NO problem at all! . . . . . And they were pretty darn tight I'll tell you! :wink:
Lifes too short . . .
#20 PostAuthor: z1bman » Tue Dec 06, 2011 10:49 pm
was that a snap it of tool you used
Garn 1
#21 PostAuthor: Garn 1 » Wed Dec 07, 2011 12:40 am
Neat Job RB!
RegardZ ~ Garn
Taffus
#22 PostAuthor: Taffus » Wed Dec 07, 2011 8:33 am
looks like you have lost a rod and have a problem with the small end bearing on no1 cylinder.
Every little helps!
(\__/)
(")_(")Image
KeithZ1R
#23 PostAuthor: KeithZ1R » Wed Dec 07, 2011 9:21 am
Weld a length of square section bar to whats left of the nut or even a new nut :?:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
jimmock
#24 PostAuthor: jimmock » Fri Dec 09, 2011 7:47 pm
I'm known for my engineering help on this site....
You could take the engine out the frame,
Tip it upside down, prefereably on a chain pull arrangement.
Remove the oil filler cap and drain the oil through the filler hole.
Refit the engine in the frame and fill with new oil.
Job done, no real dramas!!
Jimmock.
Jimmock. :wnkr
I hate people I don't like !
#25 PostAuthor: Pigford » Fri Dec 09, 2011 7:52 pm
jimmock wrote:I'm known for my engineering help on this site....
Jimmock.
Z1parR
#26 PostAuthor: Z1parR » Fri Dec 09, 2011 7:54 pm
Anybody would think you had real mechanical bent James :wink:
You seem to have a solution to most engineering woes :up
0172 . Geoff Parr
andyb1962
#27 PostAuthor: andyb1962 » Fri Dec 09, 2011 9:00 pm
Jimmock.
thanx for that but ive already done it now .............sods law eh!
i drilled the sump drained the oil sealed it with a self tapping screw and blu tac............................sorted :wink:
Andy :wink:
jimmock
#28 PostAuthor: jimmock » Sat Dec 10, 2011 1:00 am
My method would have been much more effective and quicker.
Jimmock.
Jimmock. :wnkr
jimmock
#29 PostAuthor: jimmock » Sat Dec 10, 2011 1:00 am
Z1parr wrote:Anybody would think you had real mechanical bent James :wink:
I have a lathe you know!!
Jimmock.
Jimmock. :wnkr
