Z650 fuel tap
davy thomson
Z650 fuel tap
#1 PostAuthor: davy thomson » Sun Nov 20, 2011 9:59 pm
One for the Z650 boys will a B model fuel tap fit a Z1000?
1000 posts reached that will do for me,over and out.been fun.
Taffus
#2 PostAuthor: Taffus » Sun Nov 20, 2011 10:20 pm
(\__/)
(")_(")Image
davy thomson
#3 PostAuthor: davy thomson » Mon Nov 21, 2011 7:52 am
Wrong type the A2 has the twin bolt fixing.does anybody know what the hole pitch is for the 650 ?
Crofty
#4 PostAuthor: Crofty » Mon Nov 21, 2011 9:33 am
I will measure and get back to you
Crofty
#5 PostAuthor: Crofty » Mon Nov 21, 2011 9:43 am
Approx 45mm between centres
davy thomson
#6 PostAuthor: davy thomson » Mon Nov 21, 2011 10:45 am
Thanks Crofty problem solved same size :)
Crofty
#7 PostAuthor: Crofty » Mon Nov 21, 2011 10:48 am
Excellent, wonder if part number is same?
davy thomson
#8 PostAuthor: davy thomson » Mon Nov 21, 2011 1:04 pm
No the taps are different,I am changing to a a simpler on off reserve set up instead of the vacum tap.and the 650 suits and Zpower sell them. :)
Crofty
#9 PostAuthor: Crofty » Mon Nov 21, 2011 4:53 pm
I know Z Power had the vacuum type down as fitting all 650B/C/D/F and 1000A2/A3/A4 etc
https://www.z-power.co.uk/merchantmanag ... cts_id=436
Did your 1000 originally have the vac type when brand new davy?
davy thomson
#10 PostAuthor: davy thomson » Mon Nov 21, 2011 6:02 pm
Yes Crofty but I had problems with the carbs and the fuel was pissing everywhere I stripped the tap but all seemed ok so its down to the carbs,I just want to be able to shut off the fuel when I want,and not leave a petrol trail round the north of Scotland. :lol:
Crofty
#11 PostAuthor: Crofty » Mon Nov 21, 2011 8:45 pm
I might be missing the point Davy, but if your carbs have a prob, then they still will have if you change tap. Yes the fuel won't flow out if the tap is in off possy, but then if old tap appeared OK it should not let fuel past when engine not running, easily checked by pulling hose off and trying in on and reserve positions, it would let fuel flow when switched to prime.
Where was fuel pouring out of carbs from? Was it a lot, all the time or intermitent?
